Rear window wash
Flowerman
I haven't owned it that long so don't really know,  i will have to pull out the splash pan and have a look, i know the main screen wash is in the reservoir its just the sound of the rear one seemed tobe behind me, thanx for your response
I think you’ll find there are two pumps mounted on the bottom of the washer bottle which goes through the inner wing. To gain access you will need to ease back the plastic wheel arch lining at the front of the wheel arch. This will be made easier by jacking the car up and removing the drivers side wheel.
You might find that it’s just corroded terminals and a clean up might get it working or it that doesn’t get it working then you’ll need a replacement pump.
I had this problem on my daughter’s Yaris only it was the front washer and it was just before MOT. I didn’t have enough time to get a replacement so I swapped the pumps over so it was the rear not working as the rear washer is not an MOT requirement.
