GPS issues
Hi All,
So the last few months or so I noticed that on start up there are issues with the sat nav, in particular the GPS (boxed is greyed out).
It loses location while I am driving for around  5 to 10 minutes, then it finds "signal" and location is fine.
This would only happen now and again,  but the last week it had been everyday.
Has anyone else had a similar issue regarding the GPS?
If it is a GPS antenna issue, where is this located?
Thanks in advance.
GPS antenna is under the top of the dashboard, slightly to the right of the centre screen near the centre dash speaker. Do you have a replacement windscreen fitted?
