Tire pressure monitoring system 2016 es300h
Peter from Texas
While driving tpms light started flashing then came on full time.  Checked tire pressure via the dashboard and all tires had dashes.  A tpms reset not available on this model.  The tpms indicator has turned off but still dashes indicated for all tires.  YouTube recommended that it needed a visit to the dealer.  Is there a DIY fix?
Have you driven it much since as it can take a 20/30 minute drive to reset?
Try this
when stationary and tires cold set the tyre pressures to 2.4 bar  or(35 psi)
go to TPMS menu and select recalibrate and then drive  until the tpms shows the tire pressure. It can take a while for the reading s to come and stabilise.
if this fails to work could be fault in tpms system … visit mr Lexus ….
i
