Battery charge and fuel gauge missing from dash.
My 450h+ is a month or so old.
Returned to the car today after a walk and as we were both wet and cold started the car in HV to get some heat. I have not used that before. After a few minutes drive I noticed that both sides of the dash display were empty - no Battery charge level and no fuel gauge. Passing thought - not likely - that maybe the display was different for HV. Tried the alternates with same result. Switched car off and on when I got home but gauges still missing. I'll phone Lexus in the morning.
Any ideas or anyone had that problem?
29 minutes ago, BillSt said:
I often do long runs so do use the HV mode. Never noticed any problem with missing guages.
Thanks.
I think it was just coincidental that I was in HV, as you would always want to know the state of charge and remaining fuel.
Found a useful bit in the guidebook - started the car with the selector in Neutral and it has reset everything back to normal. So far the only lasting indication is the trip odometers reset to zero.
