Leaking brake fluid in Sc430
Buckey75
Hello,
My brake master cylinder reservoir tank on my Sc430 is leaking , does anyone know where I can get a replacement please?
Edited by Buckey75
48 minutes ago, Buckey75 said:
Hello,
Would that be from the plastic being split or maybe an O ring underneath ?
46 minutes ago, Buckey75 said:
It's a hairline split on the tank
What year is your SC ?
I’ll try see if the part is sold separately.
…..looked at your previous post a 2004 👍🏻
It does appear to have its own part number.
 Another option is to contact Paul Frost who runs a Lexus dismantlers.
https://www.lexusownersclub.co.uk/forum/topic/121168-paul-frost/
shown with its own part number..
check with your local main dealer if that’s the correct number for your car .
47220-30130
Update, it now appears the leak is from the o ring at the bottom of the reservoir tank.  It appears Bob King, you are correct.  My first contact with lexus regarding this, they tell me I would have to get the tank with the o ring attached.  If they are correct it's the same difference.
If it looks like a standard O ring, most car spare shops / motor factors would have a tray of different size O rings, pop into one and get them to matched it up .
If it looks like a custom seal for that reservoir only, you’ll have to buy the whole thing from Lexus .
have you got a photo of the underside of the reservoir ?
Thank you Bob King, I will remove the o ring and try some motor factor places to see if they have a similar one.  If not I will order the box from amazon.
