Options to reduce cabin noise in the Lexus ES 350
CBG100
Hello.  I am on the verge of purchasing a new 2024 Lexus ES 350.   One of the features that is important to me is a quiet cabin (quite ride on the interior) for the driver.  Are there are any options or features that I should be looking for to maximize how quiet the car is for the driver?
Thank you in advance for your thoughts.
Best,
Charley
In the UK the ES 300h F Sport and Takumi grades have active noise cancelling. I assume this functionality is available as standard or an added extra on some of the grades offered in your country on the ES 350?
Typically the larger the diameter of the wheel the more noise is transferred to the cabin so consider grades will smaller wheels. Certainly worth test driving the options available if you can.
Use the volume button on the Mark Levinson.
I found the brand new ES f sport I had as a loan car while mine was in for a service to be pretty quiet while cruising on the motorway.However,plastic seats on a car at this level... unbelievable.They could at least have used fabric,or more appropriately,leather.
I think the Premium Pack also includes ANC ?
Yes you are probably correct - I know there are errors/contradictions in the press material and brochure. Either way, specs can vary greatly between countries so it doesn't mean it is a standard feature for Charley (I'm assuming he isn't in the UK as the ES 350 isn't sold here).
