P0340 & P0093 codes on IS220d
HI,
My car has come up with the following codes after cutting out, then starting and driving fine for a couple of days and then happening again.  In between it happening again i took the codes and cleared them.
The codes are P0340 Camshaft Position Sensor & P0093 Fuel Leak (which i dont have)
Are there any common issues with these? any easy things to check before i have to haul it into the local garage?
Any advise would be appreciated.
Nick
There cars are very unreliable, but to be honest most of issues are injector/DPF/EGR related... sort of typical diesel issues. On top of those issues - cherry on the top is head gaskets. So you get all normal diesel issues + Lexus (Toyota ) special sauce on top.
Could fuel leak be injector leaking... yes. Camshaft position sensor failure is kind of random, not sure it is more common on these than any other car, but it is kind of strange that it came up at the same time. I probably would be inclined to clean the codes and drive for a bit to see what comes-up again as they don't look related.
