Hellllp
Ok people. I changed my mad sensor and my other oxygen sensor on the pipe. My engine management light was on along with trac control light. Very sluggish upto 2200rpm. Tried disconnecting Battery for 15 minutes. Took it for a drive, used an obd2 to try and delete the code. But nothing. When I start it up white smoke comes out. I have run the engine and disconnected mad but it doesn’t cut engine out. Please help
On 5/24/2024 at 10:18 PM, Carlh said:
Ok people. I changed my mad sensor and my other oxygen sensor on the pipe. My engine management light was on along with trac control light. Very sluggish upto 2200rpm. Tried disconnecting battery for 15 minutes. Took it for a drive, used an obd2 to try and delete the code. But nothing. When I start it up white smoke comes out. I have run the engine and disconnected mad but it doesn’t cut engine out. Please help
was the MAF sensor faulty, what was the reason for changing it? You can normally just clean the MAF sensor and the throttle body yearly and thats good enough maintenance
If it smokes white, (more than condensation) it's most likely going to be your head gasket as it burns coolant. Common problem on this diesel.
Well the error code I was getting was for the Maf sensor. So changed it. Still sluggish upto 2200rpm and white smoke when start the car
Only on start up a quick puff of white
