Fitting Kit For Is200 Sideskirts.
ajp
In the end the bodyshop sorted this quite easily, they had a spare kit lying around which they used for the rubber seals, as for the attachments, they didn't have these so just bolted the skirts to the bottom.
You've all seen the results :P
Thanks for all the help guys!
  • 5 months later...
I'm having the same problems ! - any ideas anyone ?
I have set of TRD skirts, but they I need the rubber for them too, and also ...
I have no holes a the bottom of my car to bolt them from underneath ? the wheel arch holes are fine ........ but I don't have any underneath ! ?
scarface, you can get the fitting kit from chris s :D you will have the holes under your car (you have to make them) :D
