general info required
:?: Greetings everyone. Just a few questions to you tech wizzkids out there. 1. If I disconnect my Battery, will my radio have to have a code entered when its re-connected?
2. What make is the audio system?
3. Where can I obtain a wiring diagram ?
The car in question is an early GS300 which is a damage repaired {badly repaired at the moment} and im missing some info booklets:eyes:
Yes.
It's made by Pioneer specifically for Lexus. It's a non-standard OEM design, which means it's tricky to change the head unit/amp/CD player separately.
From your Lexus dealer. Call your nearest one and ask him to fax you the wiring diagram from the service manual. He should oblige.
Stevie
