17" 18"
As long as you get correct offset and bore size. 18" will fit fine.
Although some people who have fitted 18" have then lowered the car as they thought it looked a little high on 18" with standard springs/ suspension.
You can swap to 18" no problem AS LONG AS:
The Offset is right!
You need an offset of around 42 - 50 to be trouble free!
I have an offset of 41 (loooooooooooooooog story) and the fronts rubbed abit - but I got the plastic arch liners just heated up and pushed back. I am lowered 30mm too.
Good Luck! :D
Imi is currently selling some nice 18" alloys on the Buy and Sell Forum.
the width of the 18" will make a big difference to fitment issues as well  :whistling:
remember that lexus actually fit 18" wheels as an extra to standard cars
Thats true.
My wheels were 8" wide - while the standard lexus ones are 7.5J I think which is another reason why the fronts rubbed slightly.
Don't worry - just pick some wheels and I'm sure someone will be able to tell you if they will fit properly on the forums.
