A Strange Water Leak...
I noticed today that, just behind the front roadwheel on the driver's side, there's a small rubber bung in the floorpan which in my case was slowly dripping water onto the driveway!
Is this some sort of cavity drain hole? It seems to be situated just forward of the footwell.
Odd thing is, it seems to be of solid rubber (as opposed to a hole blocked with mud) and the water was seeping found the edge of it.
Should I be worried?
R
All cars have them they are a drain plug ,but it should not be leaking water .if it is then you have problems and probaly a footwell full of water .press the carpet on the side of the plug and see if it is wet .my bet is that it is the air con that is dripping like fluff states .
Nothing to do with the a/c. Seems to be a cavity drain - just forward of the front footwell. Carpets are dry.
