20k Service
I had my 20k service (@14k on the clock) at Lexus Leicester. Quite satisfied with the service except for a 'little' incident with the receptionist.
Mark mentioned that all my tyres are showing signs of under inflation. I usually stick to 32psi. Should I up that? There are signs of excessive wear on the front insides as well and the tyres have been swapped front to rear as well.
The report also showed signs of leakage in the oil pump area, but nothing was done to remedy the problem. Is this a known issue and are there no solutions?
I had reported signs of corrosion on the brake callipers (white flaky deposits) and was told that nothing could be done and Lexus doesnt consider this to be a problem. I can understand that these are solid pieces of cast iron and the corrosion doesnt affect its performance, but surely there is corrosion and needs to be sorted out. Anyone experienced similar problems?
