Fans Front Of The Radiator Won't Stop Help
Salacak
I just replaced the water pump, timing belt and A/C compressor and after picking up from mechanic shop realized fans (2 fans front of the radiator) won't stop.Car is not running hot or anything, even in the morning cold engine they come on right away. Also RPM when idle at 0.1 not at 10 or 8.
Mike :angry:
Mike :angry:
Thank you I will do that but he seems like no clue about what happened
Mike :angry:
Is your air con on at this time? I believe that these fans are for the air con radiator and designed to work like this, the engine radiator cooling fan is mechanical.
Regards,
Chris Vince
