Hi all,
having changed the wheels from the MK I standard 15 inchers for the bigger 16 inch mk II's should I have the wheels re-aligned? Is the offset different or anything that would upset the suspension etc.?
Many thanks.
Yes... and No? the LS400 has a tyre size range from 205mm to 225mm wide all with no direct geometrical compensation offerd by Lexus (thats the no) But the toe is set on the basis that the rolling resistance will encounter 205mm of contact, add 20mm to the width then the resistance must be higher. In addition the bigger diameter wheel has a greater rotating mass and will be harder to 'lift out' of a turn, this can be offset via a lower castor angle, that was the (yes).
