Timing Belt Tensioner Falure Is200
Fatbillslim
heard a faint screaming noice from the engine it done 70'000 had a belt but not the tensinor do thay bugger up??
got a flat batt only noted after bump starting then took it for a run but is the same??
I had my belt done at 95.000 i was told by the dealer that did it that the tensioner is not required so can only assume they dont fail :)
