Wind Noise
ApieLexus
Quick question:
There is some wind noise coming from my driver side door (=left side in my case).
How can I adjust my door so it closes better? Just "bend" the door? :crybaby: How do you do that?
Rubbers are ok. The Lexus dealer made some adjustments, but I think there still is too much noise on the freeway at about 75mph (=120km/h).
The passenger side has no wind noise coming from the door.
Thank you!
just a thought,  but maybe the noise is coming from the wind passing over & through the seems on the wing mirror???
you might wanna check that out before you start messing with your door.
just an idea anyway.
Good one.
But I thought since the other does not have the noise, it must be the door or window (I might be wrong ofcourse!) Any idea how to fix or exclude the wing mirror problem?
Good one.
erm, not a technical way.....but if you cover the seem with your hand when you start to hear the noise it should stop (if its coming from there). as for sorting it out....not too sure. ask lexus what they would reccomend. but rule it out first!
