Alcantara / Suede Trim
Mr Morse
"Meguiar's Quik Interior Detailer™ Interior Wipes" is great but I use "Meguiar's trim & floor cleaner" as that's what I could find in my area. Not sure if it can cause any damage if use on the leather trim around the Alcantara.
Ultra suede :
(Escaine, Alacantra) Should be cleaned by brushing the nap with a soft nylon upholstery brush, remove pilling with a single-sided razor blade and then applying a cleaning solution (Water /Woolite® or Dreft® with a ratio of 5:1 or stronger) on to an applicator pad and apply to one area at a time (do not soak the fabric) Localized stains can be treated with a citrus-based cleaner, ensure surface is dry before use by leaving window cracked/open
Do not use- steam or hot water
Identifying characteristics- very soft to the touch will scratch or scuff very easily; water drops will darken the leather but it returns to its original colour after drying.
[ each one / teach one, then student /becomes teacher ] JonM
