Creaking Bush
whiteman
whilst driving I have noticed a creak coming from nearside, did a bit of investigating and found it to be lower arm inner bush, so give it a squirt of the old WD40 type oil and it cured it for a while, it has come back but not as bad, is it time to change and also the car is getting geom done friday!! :crybaby:
So if I change afterwards geom needs to be done again,
It is a expensive doo for a bush, £133 - LOC discount...
so do I change it or put up with a creak?????? :excl:
Does this creak occur when going over speed bumps ? Also, when you make a slow turn ?
I have the same issue on an IS300 SC. Both sides do the same, although the nearside is by far the worst ?
Also, I still have a Lexus warrenty. Do you guys think it will be covered ?
doesn't do it over speed humps, only sometimes when turning and braking
Reads worrying......Surely the bush cannot be seized..... not with all the work done in that area?
Go give it some WD spray a few more times otherwise Friday will develop nothing more than a 'hand shake' :crybaby:
Note to you
Are you absolutely sure i can fit the cameras on the tyres?
Not sure?.... go into wheels-inmotion.co.uk then the LOC meet..... view the equipment in action.
Would be a sorry day if you travel......miles for nothing!
Note to you
Yes cameras will go on, got stanard wheels and tyres fitted.
The creak only occurs when turning and some times when breaking,,,,,
It has only started creaking since the 'other' place messed around with it, before that no creaks.
Note to you
Phew...... All is well then!.... Friday as of this moment will be known as 'G' day......
Three days and counting.......'A Trusted Centre' may get shot down! and off WIM!
To be continued:-...........
Note to you
sprayed plenty of the old wd40 gear everywhere, all bushes that I could see, went for a long drive country roads and bumby roads...........it has stopped!
look forward to seeing you G day
