Trd Rear Skirt
Hi all,
Having just purchased the TRD rear skirt, i was wondering how on earth it is fitted??
I have searched the forums, and have read that the rear bumper needs to be removed, is this correct?
Also, any more hints and tips on fitting would be appreciated as i dont want to cut holes in the wrong places.
(if that is how to fit?)
thanks
Simon
Hi all,
thanks
Simon
the bumper does need removing, also there should be a fitting kit if the skirt is new and still boxed
Hi all,
thanks
Simon
It is not new but i do have the fitting kit
  • Topics
  • Our picks
    • All-new Lexus RX: luxury expressed in interior design simplicity
      Lavish details and flourishes are not necessarily the best way to express luxury. A “less is more” approach with design simplicity can be a much more effective way to communicate high quality, as witnessed in the interior of the all-new Lexus RX
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
