Is300 And Gs300 Throttle Bodys
Fargo
thats an interesting point mat,, how would the LS TB benifit..
on forced induction it will create less of a restriction, the best oem throttle to use would be a Nissan Q45 throttle body, which can be picked up cheap in the US of A
the throttle body goes on the induction manifold, not the exhaust manifold
it isnt a direct fit, but can be made to fit, the q45 body is 90mm, i have a 125mm Mustang throttle body with twin butterflys, ill be using....at some point
  • Topics
  • Our picks
    • All-new Lexus RX: luxury expressed in interior design simplicity
      Lavish details and flourishes are not necessarily the best way to express luxury. A “less is more” approach with design simplicity can be a much more effective way to communicate high quality, as witnessed in the interior of the all-new Lexus RX
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
