Wirless Key
Any else having trouble where the windows open when you don't expect it.
Three times now this has happened to me. Once at work a colleague drew my attention to the windows being open. One morning I went out to the car to find the car unlocked and all windows down. Today after washing the car my wife called me to say the windows are down when it was pouring rain.
Initially I wondered if some other signal was interfering.
Now I think that the unlock button on the remote is being pressed while in my pocket maybe by a coin or a key on the keyring or something.
Its a bit annoying. Has anyone else come across this
J
Yep, happened a few times to me. I also assumed it was something in my pocket pressing against the unlock button as well. I tend to keep the key in a separate pocket now. I can't say that it's a feature I've had a need to use yet (on purpose).
if you keep your finger pressed on the unlock button after a beep all the windows open, likewise if you keep the lock button pressed they all close. i find it handy if you wnat to air out the car before you go for a drive on a hot day. you can do it from a good distance away or in the house. the car relocks but leaves the windows open automatically if you don't open the door.
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
