Replacement Cd Player
I have had err3 on my unit and intend to buy a used unit to replace mine (Is200 2000reg) i have seen a couple (bottom slot, as is mine) but the numbers are 13902. the number on mine is 13905. Will either of these be compatible?...i understand that the connectors are different on some. and you should match up the numbers on the unit. Does it have to be an exact match?
cheers in advance
