Sign in to follow this
JOE LEX
Synthetic Oil
i AM NEW TO THE SITE AND DONT KNOW QUITE HOW TO MANEUVER AROUND ! i AM TRYING TO FIND OUT IF ITS SAFE TO USE SYNTHETIC OIL IN MY ES 300 / 2002 / ALSO MY AUTO AVG MPG METER IS NOT READING RIGHT IT STAYS AROUND 20MPG & 18 MPG WHY IS THIS NOT FUNCTIONING PROPERLY IS THERE A WAY TO RESET
Hi
I have a GS300 (2000), which I presume has the same engine as yours. I have regularly used fully synthetic oil (Mobil 1 - 0w-40) and have not encountered any problems.
In relation to your MPG 'meter' you may wish to reset the ECU. You can do this by taking the leads off your Battery for 10 mins and then reconnecting them. This will reset the ECU an MAY resolve you MPG meter. However, you will need the security code before you do this.
If you do alot of town driving, the mileage may be correct, as the 300 engine is very thirsty around town. I can also do 20mpg if i do alot of town driving.
Good Luck
Mohammed
Ps, There should be a caps lock button on your keyboard.....do you know how to navigate to that? :P
Mobil one causing sludge???? Not heard of that before unless its used for about 2 mile jpurneys a day.
