Ciggy Lighter In Front Not Worky !
Sorry to bother all you busy lexus owners from "waftin around in sheer opulance" for a minute BUT !...want to fit a Tom Tom sat nav or similar and discovered the centre console cig lighter not working...the rear door ones are OK...is there a simple fix lads ?...before I go in blind and start lifting covers under the bonnet...cheers again for all your good advise over the last few months. :blink:
I have a 98 ls. Tracked it down to the wire from the harness to the cig lighter. It was intermittent. Was very careful, found 18 AWG wire and carefully replaced both wires. Lasted about 3 or 4 openings then it stopped working again. Broken wires again
Looking carefully how it worked. The wires twist when you open and close the lighter door. Found in a wire manufacturer's catalogue something they called high twist wire. Have not bought it yet but hope that is the solution. Another thought it to use small braid wire. Whole bunch of small wires woven in a cylinder shape. This is sure to be flexible.
Sorry I really do not have a good solution yet!!! Will work on it
Ron
You could go the way I did...
I needed more 12v sockets for gps, pda/phone and blue tooth headset charging, so I took up the base out of the tray in the arm rest took the tray out, under there is the wires to the rear facing cigy socket and I bought a 1 male to 3 female adaptor for about 3 quid from flea bay, cut off the male striped back and soldered it to the wires to the rear cigy socket (drilled a 5mm hole in the tray and fed the wires through first).
Now I have 3 sockets to charge stuff and all of it can be out of view in the arm rest so no cheeky monkey ties to break in just to steal a blue tooth headset ect.
i had that when i got mine found out when fitting the computer that it was not pluged in
just pull the wood up and see what you can see
I ll do that Matt...just as soon as I figure out how to get the wood out the way without damaging it !...any tips ? ;)
just put a knive or screw driver along side the wood and plasic stuff and leaver its only clicked in i take mine out loads it the min takes two tics and its out
i was the same when i first tryed it but u wont brake anything its a lexus
