hi all,
have a 92 w/ 130k. everything fine and well maintained, except i'm losing about 1/2 coolant reservoir slowly over every 2 months or so. no smells, no startup mist, no water in oil per oil report, power fine, etc... any thoughts? thanks.
Does the radiator drain plug have a rubber o-ring round it? If so then if the o-ring wasn't renewed when the antifreeze was changed it could be the source of the leak.
Mine seeps permanently from the seal round the sensor in the top of the reservoir. I've replaced the O ring, put tape (the white stuff used for radiator valves (PTFE - just remembered!!)) round the thread, nothing makes any difference, so I just top it up with about a mugful every month or so.
