Disconnecting Battery Mk1 Vehicle - Problems ?
I understand that be disconnecting the Battery that I might change some settings or delete some fault codes on the Mk1 or is it only the radio & clock that will be affected. Has anyone experienced problems of any kind ?
Any comments appreciated.
(Will use opportunity of possibly replacing Battery anyway as not holding its charge too well.)
