Medion Sat Nav
Rikos
Hello all,
My dad has a Medion sat nav and would like to update it as it's a couple of years old. I've had a look through the book that came with it and cant find a way to update it. I'm assuming you'll have to plug it into a computer and load in the new software, is this correct? Does anyway know if you can get a new disc and if so where from?
Thank you for any help.
You can get update patches and updated firmware from www.medion.co.uk
If you want to update the maps, you will need to find which mapping software you have on the device (navtec,tomtom etc)
more info can be found at www.pocketgpsworld.com and you should find links to update the maps.
You are correct that it will have to be connected to a pc via a cable, or you can remove the flash memory card, and use a card reader which is prefered.
John
