Engine Truble
Fanners
Ok, if its not going about 3k...
Check for codes,
If NO codes look at...
1) Fuel pimp
2) Fuel Filter
3) Ignition coils/leads and Spark plugs
4) All the o/2 sensors and CAT sensors
- Can you smell fuel not being burnt correctly.. at the exshaust side..
and most importantly .. are you using the same kind of engine.. with the same ECU
Edit
Iam guessing you have check the EARTHS on the engine.
