Spark Plugs
el_gencer
Where's the best place to buy a set of Denso IK20's ?
The o'l girls not firing up first time some mornings and the sparks are probably due for replacement anyway.
Also how easy is it fit them ? (I'm sure there's a guide on here somewhere)
eBay, very easy to fit, take airbox off, you will see 6 coilpacks with 10mm nut holding them in place. undo, unclip the wire's, lift coilpack up, then you can get at the plugs.
HI Guys,
Just a quick one, how does the Denso IK20 compare performance wise to the plugs that would be fitted by the dealer at normal service?
