Help - Hid In Is200 2003?
Hi matey. HID lights are a lot whiter than normal halogen bulbs. They appear blue by comparison but they're actually just a purer white. It is possible your IS has them as standard if it's the LE model although it's unlikely if it's any other model. Just turn them on and look at them, if they don't look pure white or blue, they're not HID's.
Keith :)
As Wylie says, unless it's an LE (which I think came out in 2004, poss end of 2003) it won't have HIDs.
Another way of checking is whether you have a headlight height adjustment switch to the right of the steering wheel - if you do, you don't have HIDs :)
My one is "SE"
If it's an SE, it's the same as mine - no HIDs I'm afraid. I've fitted them myself though, doesn't cost that much and very easy to install. I can highly recommend doing it :)
