I have just bought a '00 IS200 in UK and drove it back to Ireland,
when I arrived home I desided to start lookin at everything... then came
across the headlight washers and proceeded to push and only the driver side
worked... didn't mind really it is 8 years old but then I did it again a few days later
and it switched around and now only the passenger side is working... woundering is it
and easy fix job or what???
Welcome to LOC.
I think the headlight washer jets maybe sticking, you might be able to free them up by spraying some WD-40 on the mechanism (lift out the washer jets). Worth a try...
