Manifold Removal
coolrides
I have noticed on the first link posted by Carles (head removal) on step 16 it does mention: RHD: REMOVE STEERING SLINDING YOKE.
So I guess it is not necessary to remove anything (aside the old manifold) from a LHD car.
Yes thats right :D yours is on the other side( steering) :D
hey again. just seen the steering joint and it is very easy to remove, 2 12mm bolts, take them right out as it makes it easier to remove, just mark about 2 inches above and a small mark below to aid refitting in same position. manifold still tight to remove through the space but it will come, make sure the 2 sensors are unscrewed. 22mm spanner
