Help Resetting Ecu
hi all
well i got my plugs changed and needed to reset the ecu
this what i did
turn the car off
take out fuse box
take out 20/25amp efi fuse
take out 15amp etcs fuse
for 30 secs
did that and it did not reset the clock and trip or anything
does it need to reset the clock ?
or is it done
hope you guys can help
wahid
I don't think if you pull the fuses you loose the clock/radio settings.
If you disconnect the Battery to reset the ecu then you loose the clock/radio settings.
