New Head Unit
HI guys help needed i am going to fit a new head unit this week end can anyone send me a walk through guide on how to remove the factory item and the dash top tray regards
hi mate..first get masking tape and tape off the sides of the dash(you dont wanna scratch your dash)
the top tray just pulls off(pull it towards you) then pull the pannel with the trc buttons on it towards you now you will see two 10mm bolts at the top and two at the bottom remove these and pull the stereo and the heater controls out(they are joined together with screws and a frame either side)remove the screws and the stereo and the heater controls will seperate now rebuilding is the same as removal.
hope that helps.
hope that helps.
thankyou guys all fitted quite straight forward really a bit of trouble connecting the bye pass cable that said only took around 2 hours that incuded fitting a Bluetooth hands free kit thankyou again for your help,
