Is200 Rear Seat Removal.
ok here you go
bottom seat there are 2 poppers under the seat. if you lift it a little and move into the middle you will see were they are. they just lift up.
then the back has some bolts at the bottom that need removing then the back needs pushing up as there are 3 hooks the top of the back lock into
