Hello Guys,
I noticed that the orange sign - low fuel indication - is not illuminated anymore when I power up all the electronics - engine is still off -
When you press the start/stop button all the indications come up and after a few seconds they dissappear, indicating no permanent problems. The low fuel indication is not appeared at all.
Did you come across the same problem?
When my ignition sequence starts and completes the low fuel indicator does not light up. However, it does light up when my fuel level is low so it does it's job.
Hope that helps and is consistent with what you see.
