Bottom Loading Cd Players
gary2009
Hi all recently the cd player packed in with the common err3 message and i bought another bottom loading one off of ebay but the connectors on the back are completely different is there anyway around this ? or did lexus change the design of the bottom loaders before they bought in the top loading ones?
Any help would be appreciated .
Gary
When buying replacement CD units, you got to make sure the replacement one you are buying has the same code.
For example, if your unit is 13902, your replacement must also be a 13902. As you have discovered, the connections are different at the back with different units (mines a 13903).
Sorry, I don't know if there is a way round your problem.
thanks for that cam its very much appreciated.
  • Topics
  • Our picks
    • All-new Lexus RX: luxury expressed in interior design simplicity
      Lavish details and flourishes are not necessarily the best way to express luxury. A “less is more” approach with design simplicity can be a much more effective way to communicate high quality, as witnessed in the interior of the all-new Lexus RX
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
