Removing Cd Unit From Is 200 Se 2003
easy to remove, its been covered a fair few times on the forum...
only is200/300 units will fit in an is200/300
Hi thanks for the help ,so are all units inter changeable .im thinking of getting one from a 2000 year one ..
no they are not you need to ensure your replacement unit has the same code as the one fitted, the correct code can be found on the unit face
it says the same ive been told ,just not sure if to gamble its from a 2000 year model ,and wont accept returns
