How Remove Radio/cd Player From Is200
Have a look here
Topics covering bits like this can be found in the workshop section or in the audio/visual section :winky:
Good luck - thread linked to above I think has a walk through so should be easy to follow :D
http://www.lexusownersclub.co.uk/forum/ind...?showtopic=1161
http://www.lexusownersclub.co.uk/forum/ind...showtopic=36499
those were a couple of threads i found with a quick search...
hope it helps, good luck
btw i pulled mine and i am getting it fixed by the manufacturer.
not exactly sure what the Japanese guy was saying but there was quite a bit of dust,
probably some ash since the owner before me smoked, and it clogged up some of the feeding gears.
if i had caught it early enough, would have been a simple cleaning, no parts replacement...
but most of the gears were chewed up and mangled, and some of the finer gear axles were bent out of shape,
and i think a spring sprung or something like that;
if you are just removing it to install another head unit,
you could probably get rid of it on here for a good price,
brand new they cost quite a bit, so don't get haggled down too much.
