1994 Ls400 Radio Problem (pioneer P3415
Hi all
Can anyone help before i take the car to my local radio shop??£££??
I have just brought muy first Lexus (1994 ls400) and the guy I bought it from said the radio worked fine untill he changed the Battery.
I have checked all the fuses under the bonnet and under the steering column and still no joy.
I can't see how to remove the radio to check the connections on the back.
Also what oil for the oil change
Many thanks in advance
Tony
Hi all
I have just brought muy first Lexus (1994 ls400) and the guy I bought it from said the radio worked fine untill he changed the battery.
Tony
Just found a free radio/AC removeal guide hope this helps someone http://www.saabtrek.com/accremoval :winky:
Welcome to the LOC,
You say the radio is completely dead with no display? as they normally ask for a code when the Battery is disconnected.
You could check the fuses fuse no. 4 and no.18 both located on the passenger side fuse panel below the glove box.
Recommended oil is 10w30 a decent semi synthetic use a genuine filter only.
Hi all
Tony
I know. Number of things, but have all the answers I do.
Welcome to the LOC,
You say the radio is completely dead with no display? as they normally ask for a code when the battery is disconnected.
Hi
I can't find a passenger side fuse box and have checked theowners manual and that dosn't list one either will check again tomorrow
many thanks Tony
Hi all
Tony
thats fantastic please enlighten me as to why the stereo is completely dead and the fuses are fine
