Condenser O Rings
tonz13
i am going to replace the condenser on my IS200. does anyone happen to know what size of the 2 'o' rings i will need for the discharge hole and tube.
excuse my stupidness but can i use other oil instead of compressor oil to lubricant the o rings?
Thanks in advance
Thanks in advance
P A G oil is what you will need as its what's used in the A/C system, or a little Silicon spray as it wont deteriorate the rubber, also they arent ordinary o-rings ie (black in colour) they should be green or purple, the R134a refrigerant used in your system can become corossive and will eat through standard black o-rings,
You should be able to order them through you local toyota dealer or any aircon specialist. If you still have the old ones they should be ok to re-use?
