Smoothness Taking Off From Lights
Stetz
Just wondering if the gearbox mount could be worn of something, as when I'm at the lights and drive off in 1st gear there is a wobbel from the car. If I rev high taking off its not as bad, just trying to sort problem before it gets worse.
Could be your dual mass flywheel. Mind does that occasional when its cold & I don't have enough revs on. Not a biggy but it will need replacing eventually. Good excuses to get a light weight solid flywheel when the time comes.
hello ,
you'll probably find it's the clutch mate, most likely nothing wrong with it, it's something to do with them being dual mass or something.
mine does it too if i set off a certain way.
there are a few threads on here about it, hope this helps
take it easy
EDIT: didn't see the first reply sorry!!!!!!
Yep JUN make them. Probably work out cheaper than a genuine flywheel. You're looking at around £390 FedEX'd from Japan or you could see what Prolex or Fensport could do.
Exedy make the clutch kits to suit as you can't use a OE kit with a solid flywheel due to a slightly different profile. http://exedy.com.au/...heetRowId=62668
They also do a kit with a solid flywheel included but I don't think it's lightweight http://exedy.com.au/...heetRowId=62667 A quick email to Exedy UK should be able to answer any questions you have
