When i use the windscreen washer, im afraid that the best i can manage in a sad trickle rather than a powerful spray. As a consequence, only the lower portion of the screen gets clean. I have tried clearing out the nozzles but it doesnt make any difference. Anybody have any ideas how this can be sorted?
Try to use the washer when you slow down a bit. Mine does that too when I drive fast on the highway. You can also activate the headlight washer to boost the windscreen washer. It will spray everywhere include your windscreen, hood, roof etc... Done use it if you just washed your car! :lol:
Check under the bonnet from the nozzles to see if any hoses have split or come off connecters allowing pressure to drop - not had it on a lex but have on other cars - the join pieces have one way valves on sometimes to ensure you have water at the jets as soon as you need,these often leak - open bonnet and spray washers and look for obvious leaks - hope it helps
