Clutch
Hi Guys/Gals
Looking to change my clutch fluid soon (don't think it's ever been changed since ive had the car), is there any specific clutch fluid someone can recommend?
Thanks!
hello mate you should looking to use DOT3 clutch/brake fluid .regards james
I think you mean DOT 4? Thats the standard brake fluid these days.
If you're going to be seeing an track time you may as well put something decent in there like Motul but if not 500ml of an old DOT 4 will do.
Cheers for the reply guys. In the end i bought some Motul DOT5.1 fluid, as it was near price as DOT4 ones from another store. Never knew clutch and brakes can use the same fluid, but i suppose that, it would be logical, as bascially they are required to do the same job.
