Altezza Engine In Is200 ? Help?
coffey
there are a few engines that fit but all come with there own problems. the 1g gte twin turbo fits straight in and can use the 1gfe gearbox but you will need the ecu and wiring loom. the 3gs3 will need the same and a gearbox.the 1jz and 2jz need engine mounts and lots of body work to make them fit.
