There is also a button at the bottom of the fascia well below the steering column. it is VERY IMPORTANT to switch off the air suspension BEFORE ever jacking up the car. To do this, with engine running press the button once and you will see the yellow OFF light come up on the dash just below the Hi N Lo indicator, then switch off igniton and work on car. When work finished, start engine, press button once and OFF light will go out.
