Mk Iv Power Steering Pump Question
Does the Mk IV suffer from the same problem of leaking power steering pump as older models did or had lexus found an answer to the problem by the time the Mk IV was released.
The power steering pump was relocated on later models and no longer sits above the alternator as for the leaking O ring on earlier models I haven't heard of a leaking one on later models.
