Transponder Coding
hello again
bought a key today via fleabay
as my is200 only came with one
i know i cannot use the blade, or change it
as it looks to be sealed, but i'd like
obviously to re code it to my car, i have found
the page with directions on doing this, but is it
the same process for all cars? or different for earlier models
such as mine?
regards
johnboy
hello again
such as mine?
regards
johnboy
Hi, you will have to have the key/blade cut using your current key and then programme it using the directions/instructions on here or i could forward it to you as i have also got them.
hello again
such as mine?
regards
johnboy
hello that would be great scudney thanks
i don't know how to remove the old blade as they are sealed so i'll have to buy an empty blank and swap the transponder to that i suppose? :tomato:
hello again
such as mine?
regards
johnboy
hi,hope you can find a good key cutter,take your old one with you and he should be able to cut the blade on the new one using the old one as a template,you could then swap the transponder over to the new one.
