Keys Locked In Car.....help Please
The AA levered the top of the drivers door on one of my Camrys when I locked myself out. He inserted levers to bend the top of the door slightly open at the top, protecting the door with thin srips of rubber where the levers were inserted. He then inserted a wire with a hook end to loop round the inside handle to pull it open. A bent wire coat hanger? I looked at the the handle on my GS300 and the handle is similar to the Camry. I locked the door through the open window while inside the GS to test to see if pulling the handle would release the door and it did, but I don't know if this will work if the alarm is on. Of course you could damage the door or permanently bend the door so be very careful. You could ask an AA member ( if you are not a member) to ring the AA to see if they can help.
